Possible for autometer temp gauge to be bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2005, 06:54 PM
I have an autometer temperature gauge, and I had a bare 12v wire exposed one day and the sender for the gauge hit it, and sparked real quick. When I got the motor running and the gauge installed, the gauge stays at 130 degrees and doesnt seem to move up. I havent had the motor ALL the way to temp yet, but the stock gauge reads about 1/4 of the way up and the autometer is at 130 degrees. I have a 180 degree thermostat, and I figured by the time the stock gauge is the 1/4 of the way up the autometer guage should be up to about 160 or so... I didnt think a little jolt of electricity would do anything to the gauge considering its mechanical and doesnt need power to run..
-Steve
Old 02-20-2005, 07:33 PM
lluciano77's Avatar
Short changed on common sense
It is an electric guage? You probably fried it. See if you can send it back under warranty. They shouldn't be able to tell that there was a back feed on it.
Old 02-20-2005, 08:13 PM
I believe its mechanical because it doesnt require power to run, only power for the light
Old 02-20-2005, 08:26 PM
lluciano77's Avatar
Well, that would pretty much rule out the backfeed theory.
The mechanical lines can break. Once they leak they stop working. I have had a couple go out like that. The freon or whatever the gas is inside them leaks out easily. The copper tubing breaks or cracks from being bent back and forth.
Old 02-20-2005, 11:02 PM
theres no tubing (like an oil pressure gauge) just a metal wire, covered in a protective coil, which goes to a metal probe...
Old 02-20-2005, 11:57 PM
Siggy_Freud's Avatar
Probably fried it by connecting direct current to it.
Old 02-21-2005, 04:29 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
It does have a thin tube in it,it is wound tightly,if it is mechanical.
Old 02-21-2005, 10:02 AM
bondo's Avatar
That IS the Tube to the thermo-coupler........... Not a Wire.........
If you Arced it out, It Probably Blew thru the side of the Tube/Coupler........
There for,..... It's Junk........
Old 02-21-2005, 11:20 AM
302 Z28's Avatar
The thin tube, and sensor bulb is usually filled with alcohol.
Vince
Need help with fuel gauge Crazy-J Electrical 3 03-01-2005 11:46 AM
Which temp gauge is more accurate Palmtrees57 Engine 3 10-30-2004 06:38 AM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 04:43 PM
Temp. sending unit dodge36 Electrical 10 01-14-2003 10:52 PM
69' Camaro/Engine Temp Showing Low PrimaDude Engine 4 11-03-2002 07:37 AM
