Possible bad distributor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2005, 01:16 AM
Steve-0321's Avatar
ok so i have a 1973 Mustang with a 351C 2V motor in it with 70000 miles on it. It seems to me that the distributor is wearing out. I noticed it running a little differently then normal so i checked the timing and i noticed it jumped around(this is with the vaccum advance plugged). I know that these motors had a less than great nylon type cam gear that are prone to wear out but i dont think that is the case because this motor was rebuilt and my father opted for a steel gear this time around. I also notice when i start it up after it is warmed up fully that it will run very smoothly for a couple seconds then the rpms drop and it starts to miss or something that i can hear through the exhaust. Could this be the springs? or vaccum advance? or maybe just a worn out distributor all together? I do have the Pertronix electronic ignition conversion if that helps at all. any suggestions or insight will be greatly appreciated. Thanks
Old 09-23-2005, 07:47 AM
347mustang's Avatar
could be a gear..or even if the t9iming chian is new it may be bad
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
A really bad day with a car :/ Please help if ya can esears Hotrodders' Lounge 7 08-30-2005 11:16 AM
Bad brake booster? NOlowrider Suspension - Brakes - Steering 4 05-26-2005 01:39 PM
69 Pontiac Firebird HEI Distributor Question pontiac69 Engine 13 12-01-2003 09:35 PM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 10:28 PM
