possible bad toque converter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2003, 02:51 PM
Deadtemple's Avatar
Ok.. I istalled my first transmission on monday. It is the same style as my old one. 200-R4 It took me a long time to install it. I got the tranny and torque converter from the junk yard for $200. Everything looked to be all right when I picked it up. Nothing was loose or broken, no metal peices in the tranny. The torque converter inards seem to move freely.
Now to my problem. When I romp on the throttle, she seems to not want to give it all she has. It takes off, but feels like the engine is bogging down or missing. Then out of no where she runs smoothly, and then bogs again. I checked the timing and the plugs, etc. nithing seems amiss with the engine. She idles fine too. Just when I romp on the throttle, it is not giving like she used to.
I jacked the rearend up and ran it full throttle, she did not bog down once or feel strange at all. A couple of times when I put it in drive it clunked. Also on the street, in first it whines a little bit sometimes with foot off throttle.
I have rechecked the torque converter bolts and they are tight. There is a tiny leak coming from the torque converter.
Do I need to get a new torque converter? or just take tranny back out and reseat the torque converter? Or should I just say the hell with it and run it till it dies and get a new tranny and torque converter?
I would like to fix this problem myself and not take it to the garage, monetary reasons. Any suggestions?
Old 10-09-2003, 05:42 PM
Do a stall speed test if it comes it low you have a bad stator one-way clutch
Old 10-09-2003, 05:48 PM
Deadtemple's Avatar
I just looked up how to do a stll speed test. I can not do one, for I do not have a tach in my car yet. I also do not have a speedometer either.
Things have came up and i can not get either for at least 6 months.
I guess I could do it and judge by the engine sound right?
Old 10-09-2003, 07:03 PM
Deadtemple's Avatar
I went out a little bit ago and tried a stall speed test. As I said before I do not have a tach. I spun my tires. Or should I say tire, my car was supposed to have posi traction, but either it broke and hence the whine in first gear, or it never has it.
I am leaning towards a malfunction in my distributor or spark wires or my TV cable. I am not sure. The car runs good at low speeds. Only once I romp on the throtle does it want to bog down. Tommorrow I am going to run some carb cleaner thru it and install a new fuel filter. Not that it will do anything, but just to make sure.
I did spill some tranny fluid on the hei distibutor when refilling the tranny after install. Maybe I burnt something out, I am not sure. It does not make any sense that it runs fine at low rpm in OD. I did try to manual shift and sometimes it was fine, others it still bogged. I am going to install a new TV cable depending on the price of it.
Eventually I am going to redo this whole car, but for the mean time I just need it to run right for atleast a month. A cheap fix til I get my other car back. (long story) Ohh, by the way I never mentioned that this is a 85 Monte Carlo SS with a 350 motor. My plans are to restore the underneath body and put in a aluminum motor that will be built be Atlanta Engine Co.
If anyone has any insight into my problem, please feel free to voice any opionons. Thanks
Old 10-10-2003, 01:13 PM
galaxieguy3's Avatar
Sounds like your torque converter is staying "locked" up instead of unlocking when you "romp" on it. like it is supposed to. The torque converter lockup feature is there to give better fuel economy when cruising down the highway, reducing the amount of slippage in the torque converter.
Old 10-10-2003, 08:39 PM
Deadtemple's Avatar
I guess that would mean I need a new converter, huh?
I don't even have the lock up switch connected.
It seems to be getting a little better, but still is not right by a long shot. Now I hear a slight knock coming from the converter area when in gear with the foot on the brake. also I feel a knock in the steering whell when driving. I really hate to ull that tranny back and check it. It was a real big pain in the a** just get it on.
You know working on sand is not very easy. Plus from my back no less.
Old 10-10-2003, 08:54 PM
WV hillbilly
Last journal entry: PTL 220CC
You might want to pull the inspection cover and make sure the torque converter bolts are tight..
Old 10-11-2003, 08:51 AM
Deadtemple's Avatar
I just pulled out the torque converter bolts.
I dont know if this is normal, but when I pulled my bolts out, I can push my torque converter back towards the tranny some, leaving a 1/4" to a 1/2" gap from the flywheel to the torque converter bolt holes. Is this normal? I could of swore the one I took off was tight against with hardly any give backwards.
Old 10-11-2003, 05:42 PM
adtkart@aol.com
With the convertor bolts out, you should be able to move the convertor toward the trans a little. I would doubt that you could move it 1/2". I don't think 1/4" would be excessive.
Old 10-11-2003, 06:53 PM
Deadtemple's Avatar
Maybe you are right! I did not have a measureing tape on hand.
Any how, it seems to be doing alright now. It still feels a little off, but maybe that is just because it is a used tranny.
I dont have the converter lock-up working. I tried to hook the wires up to a toggle swirch, but non of the wires seem to do anything. I have tried all three, even together. Still nothing.
I am convinced that the junk yard gave me a non locking converter. But isn't the lock-up function have to do with the tranny, not the converter?
Not sure about it, but as long as it is running fine, I am happy.
I do appreciate the help. Thank you!
You only learn once, then it is common knowledge!
