Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - possible blowby?
  #18 (permalink)
Old 01-14-2013, 07:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by CapriceLTZ View Post
oil pressure hangs around 25-30 @ 8 to 8.5 x100 rpm running @ temp
By using an RPO 9C1 sender along w/removing the resistor (located under the dash near glovebox), you can have a functional oil pressure gauge.
The 9C1 sender is 0-80 psi, so I believe the halfway point on the gauge becomes 40 psi instead of 30 psi. But either way this can be verified by attaching a temporary mechanical gauge.
