There are two Comp cams in the current lineup that use 286 degrees on the intake side, but both are circle track cams with way more lift than what you're thinking. 12-657-5 and 12-654-5 are the numbers.
If you really need to know exactly what the cam is, pull it from the motor and see the part number stamped into the rear face of the rear journal. With that number, you can call Comp and get the details on the cam timing. |
| Comp Cam Question | crystalbluevib | Engine | 5 | 03-03-2010 07:25 PM |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Comp Cams XE268 chevy cam | pds23 | Engine | 6 | 08-30-2008 01:59 PM |
| Comp cams took care of failing cam | TurboS10 | Hotrodders' Lounge | 12 | 01-08-2005 07:15 PM |
| IGNITION and CAM TIMING | sum87mustang | Engine | 3 | 07-11-2003 07:52 PM |
