eric32, there's a link to info on rotor phasing (from MSD) in my previous post, in case you missed it. It involves using a cap cut out so you can see the relationship of the rotor tip to the plug terminals.
Good luck. |
A scope and someone who can read it turns ignition problems into a ten minute job instead of hours of guesswork. Sadly, tune up shops seem to be dying out due to newer cars not needing the attention our old hot rods do. a good shop with good equipment can find components degrading long before they give problems. |
eric32, I took a look at a thread you had about a carb: Opinion on Holley 670 street avenger pics inside.
If this is the same carb you're now using, I have a concern. You mentioned the air bleed bypass in the center of the carb. Said that you were "going to leave it out for now", or words to that effect. Which should have been fine... But, if you removed the air bypass jet entirely, that could have created a vacuum leak- IF the center channel has been opened up already. If that is the case, the orifice that the air bleed occupies needs to be either blocked off entirely w/an undrilled jet, or have a small diameter hole drilled to provide an air bypass to let a big cam idle w/o opening the primaries too far, ala the BG Idle Eze. Just because the channel was supposed to be closed off, I wouldn't take that as gospel. I'd check it to be positive. |
What about the pickup coil? They can get brittle and arc out as the vacuum advance moves the plate the ignition module sits on. I had one fail once the engine got warmed up. Easy to test, disconnect it from the module and check across the leads with ohmmeter (should be 500-1500 ohms, I think wires are green and white). Check from each leg to ground it should read infinite, be sure to move the plate as you do these tests to see if they short when moved. I also helped my cousin with a similar issue, he was missing a ground strap from the HEI coil to the wiring plug on the cap. It ran great then all of a sudden did not even though the ground was missing for quite some time.
Hello guys I know its been almost a month and I finally found out my problem almost by accident. I brought my truck up to my dad's house so we had a warm place to be able to have some time to check things out. Well we looked and checked everything all over the distributor again and could not understand why it was running horrible. I took it out on the highway and it all of a sudden just quit and would not start anymore. We had control module checked and it turned out fine and also the coil was good. Well here is the kicker he said only thing left to check was the pickup and I said I never heard of those going bad just the modules or coils but he said they can so when he went to check it turns out one of the wires the green one that hooks up to the control module was not in the boot very well and there for made for a short and loose connection. He pushed it back in and boom we had fire again and the missing part sound like its maybe a exhaust leak.Some times the simple things are not found right away but a nice simple fix. Thanks guys for your input and advice appreciate it.
eric |
| Electrical problem | johntm | Electrical | 26 | 09-14-2012 07:57 AM |
| Car electrical problem causing bad Battery? | 67Elcamino | Electrical | 3 | 11-23-2011 07:22 PM |
| bad electrical problem | lets_baja | Electrical | 1 | 02-18-2008 03:55 PM |
| electrical problem | micken | Electrical | 9 | 05-03-2006 04:23 PM |
| electrical problem | SmokeGetsInYourEyes | Electrical | 6 | 01-29-2006 03:12 PM |
