Are there redundant grounds between the engine, battery, chassis, firewall? Is the distributor body grounded through the clamp, w/no paint between the metal of the clamp, the hold down bolt and distributor body?
Is the module tight to the distributor? Is the coil ground strap or wire in place and tight? |
Hello there is no paint between the distributor body and hold down clamp as its all bare as can be.And all ground connections are fine as everything was running just fine until a few weeks ago when this problem started.
I suspect your plug wires. Set your multimeter on the ohm scale, ( it's little symbol looks like headphones), 2000 or less, and grip each end as firmly as you can and look for crazy fluctuations, or loss of continuity altogether. (Meter goes blank, however briefly). MSD wires offer around 50 ohms PER FOOT. An 18-inch wire should read around 75 ohms, though it's not super crucial. I've seen some ordinary production wire-sets run several hundred ohms fer foot. Talk about giving your coil a workout... I had 2 separate Taylor wire-sets fail within a year. Never again. Remember, it only takes one to produce the effects you're experiencing.
That also could explain the 'noise' the meter was seeing.
hello guys I checked my plug wires and the resistance I got was about 5.8 ohms for short wires and 7k for longest wires. I am using auto lite wires from advance auto parts. I am assuming that these wires are still good and within range. yes I have used aftermarket wires with very low resistance but had bad radio static problems so got the auto lite wires about year and a half ago and problem solved with that issue. I don't know what else to check. I took one plug out and it was dry but still had a gas smell to it. I don't know what else to check. any ideas.
JHello guys just a update here i wanted to double check my wires and I had one that was either dead or it just would not read on multimeter cause of being that bad. I went ahead and bought a set of wires from autozone and each wire has only about 1k or resistance or less so there way better then the autolite ones so hopefully this will cure my problem. Thanks for tips.
Well guys I am posting back and I changed out all my plug wires with a brand new set and I checked thema ll before putting them on and they all have 1000 ohms of resistence or less so they are good. So I have put a new coil and cap along with a control module in the distributor which is less then two years old and I put new plug wires on. I just installed a brand new battery and all the ground wires are all new and have all been checked and I get a good 13.75 to 14 volts at the distributor when running. I also put a new set of plugs in and after all this stuff I still have the miss firing on both sides and you can hear it at the exhaust pipe as it makes a poof sound when it happens. I have checked the idle mixture screws and basic settings on the carburetor and its all fine wise there. Any suggestions on anything else to check. I am at a lost here.
Thanks Eric |
Did you do a compression test ??
Did you happen to mess with the valves ?? |
Nothing wrong with valves as I have rolled rockers and they are locked and sound normal. As far as compression test goes it has been running fine then all of a sudden it developed the issues it has. I have checked so many things I don't know what else to do. The misfire is random and is not at just any particular cylinder and is happening on both sides.
You need to take your car to a competent tune up shop that has an ignition analyzer scope and an exhaust gas analyzer. With a scope, you can "see" the exact cause of the problem without throwing parts at it.
x2 sparkc
Bad PCV valve or other vacuum leak.
vicrod |
What does a vacuum gauge reading look like? Have you done a compression test?
What about the float level? You mentioned the plugs were gas fouled- that should not be happening. Fuel pressure excessive? Plugged air bleeds? Blown power valve? See if it'll stay running or stall out when you screw the idle mixture screws all the way in (count the turns so you can return them to where they were, or plan on readjusting the idle mixture, engine fully warmed up). Could be too-tight valves. Might be time to bite the bullet and adjust the valves w/the engine running. That way there's no doubt where zero lash is. I'd still check for vacuum leaks, etc. first. Another thing to look at is the rotor phasing. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
NEW INTERIORS (01-31-2013) | ||
| Electrical problem | johntm | Electrical | 26 | 09-14-2012 07:57 AM |
| Car electrical problem causing bad Battery? | 67Elcamino | Electrical | 3 | 11-23-2011 07:22 PM |
| bad electrical problem | lets_baja | Electrical | 1 | 02-18-2008 03:55 PM |
| electrical problem | micken | Electrical | 9 | 05-03-2006 04:23 PM |
| electrical problem | SmokeGetsInYourEyes | Electrical | 6 | 01-29-2006 03:12 PM |
