Possible to get a gun back to factory clean? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2011, 11:18 AM
Is there a way to get a spray gun back to spotless factory new?
Old 06-25-2011, 11:29 AM
My guess/suggestion would be an ultrasonic cleaner.
Old 06-25-2011, 12:14 PM
TucsonJay's Avatar
You can buy a product called gun cleaner. Put it into something like and old metal coffee can... tear the gun completely down...drop it in to soak for about 24 hours... then scrub with a fine metal brush. I usually rinse the parts in lacquer thinner afterward.... then reassemble.
If you take pride in your equipment (which I don't), you can do this each time you use it. I paint full time, and don't get paid to clean equipment. As long as the inside is clean, and I don't have any problems, I don't worry about it.
I do clean the gun every time I use it, by running lacquer thinner through it once... wipe it out... spray fresh thinner again... and if the thinner looks clean, I'm done. If not, I do it a third time.
Old 06-25-2011, 12:57 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
carb cleaner comes in a 2 gal bucket with a basket. tear it down and soak it. rinse it clean with urethane reducer .
all my guns look like new. i clean each one after each use and put it up clean and lubed. wont have a nasty gun in my shop nor would i ever hire a painter who showed up with nasty equipment.
Old 06-25-2011, 01:53 PM
Irelands child's Avatar
This what my Iwata looks like 3 years later and some fair amount of use:
My other and used mostly for primers, a Finishline lll is just as clean. When I use a gun, it gets cleaned just as soon as possible afterwards and usually with a cheap, no-name thinner I get from my local auto paint supplier. That thinner will remove any and all paints as long as they aren't 'cured', even SPI epoxy
Dave W
Irelands child
Old 06-25-2011, 01:58 PM
TucsonJay's Avatar
I'd show you mine, but you guys would have a coronary! Instead, I'll show you what can be done with a nasty looking gun... (that's clean where it counts.) :-)
Old 06-25-2011, 02:06 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Everytime I see your work, I find myself more impressed. Very nice
Old 06-25-2011, 02:10 PM
shine's Avatar
SPI Thug
be careful using thinner. if it recycled it may contain acids which can etch your gun. which can really screw with the flow of air and such.
Old 06-25-2011, 02:43 PM
milo's Avatar
point on positive
When you pull that trigger air moves..not just through the gun but all around the fan,,,it creates a void and pulls in new air to replace it. If dirt is in that air weather from finally coming off the outside of the gun , the painters suit,or just floating by it is thrown onto the surface..
Think of it like open heart surgery.. do you want the scaple with a new clean blade and handle in the doctors hand or just a new blade in the ole dirty handle?
Old 06-25-2011, 03:03 PM
TucsonJay's Avatar
I not tryin' to give you guys an ulcer. :-) Just a hard time! LOL!
I bet Howie Mandel keeps his gun cleaner than anyone here!
Old 07-25-2011, 11:35 PM
fast68's Avatar
likes chevy trucks & boobies
what you lube gun with for storage and how do you go about doing it exactly?
i dont like the idea of a kind of oil since paint and oil dont like each other hmm...
interesting
Old 07-26-2011, 07:09 AM
interesting
Summit has some in a 4 oz bottle that will last you a life time (which reminds me, I need some more )
Dave W
Irelands child
What would you do with a clean 84 Z28? 6426yy Hotrodding Basics 7 01-10-2008 12:34 PM
how do i clean this ? Vortech 4.3 Body - Exterior 1 12-03-2006 12:31 PM
How to fix Lower Valance back to Factory new look? satexasf150 Body - Exterior 1 11-23-2005 02:12 AM
One clean I6 Cruiseomatic Hotrodders' Lounge 6 09-13-2004 05:20 AM
back agine still spites back throw the barb at low rpm 302truck Engine 9 01-17-2004 11:43 AM
