Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is it possible to stroke a 400 more than it already is?
Old 12-21-2002, 07:09 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I was under the impression that a 427 required the cam location change. I know there can be problems with that stroke arrangment.
1BAD80, were you able to find an oem block that worked. Also, anyone know the cam lift limitations. I would guess a big roller would be out of the question if trying to use an oem block.
I am curious because I have toyed with the idea of a 427, but my budget is not deep enough for a new block yet. Maybe the next buildup...
Chris
