Is it possible to tell spline count from axle tag? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2004, 02:21 PM
Muscle car fan
Just wondering if i need to actually pull the axles and count, or if i could decode from my tag. Rear is a 9". Also was wondering about bearing sizes, if there was any way to tell those without disassembly.
Axle was under a 74 Gran Torino
axle tag reads as such as far as i can tell
WEB-AD5 4GA
2 75 9 844B
so i know it's an open carrier with a 2.75 ratio, that the ring gear is actually 9" that it was assembled on a monday of July in 74 (4GA)
Also i got a used gear set for my rear i was planning on swapping out (why i would like to know bearing sizes ect) and it's ring gear is quite a bit smaller than 9". it's an original FoMoCo gear set that i got used in great condition, it's 3.56 which i've heard is supposed to be uncommon, anything i should know about the smaller ring gear? or should i get a set of newer gears in a diff ratio that will actually have a 9" ring gear
Thanks for the help
Dubz
'74 Gran Torino Project
351W, c6 trans, 9"
Old 10-12-2004, 05:36 PM
aka Duke of URL
28 Spline Count
Carrier Brg Cone I.D. 1 25/32" CUP O.D. 2 57/64"
Wheel Brg Tappered Roller I.D. 1 9/16" O.D. 3 9/64"
Do you see any I.D. markings on the RG/Pinion?
Old 10-12-2004, 11:14 PM
Muscle car fan
I'll have to go dig it out and get you the casting info from them, i know they have numbers as well as the FoMoCo logo, i wrote them down a while ago but lost the paper.
351W, c6 trans, 9"
Old 10-12-2004, 11:25 PM
bud-23's Avatar
Are we having fun yet?
Hey KLUTULZ. I have a Lincoln Versalis sp? and when I changed gears I found out there were 3 different bearing sizes. 130 mile round trip to get the right ones.
Norm.
Old 10-13-2004, 12:44 PM
Muscle car fan
RG markings
FoMoCo logo U.S.A WAC-4210-A |> 8 5 88 Shift #3 B6
PG marking
FoMoCo logo WAS 4610 A |> MX 1 USA
RG has 32 teeth
PG has 9 teeth
i think i maybe got hosed as if they use the same kind of code as the axle tag i have a 5.88 gear from a 8"
looks like i did get screwed, ring gear measures 8" outside diameter, inner diam 5". Pinion gear measures 4.5" across. The 3.56 gear wasn't common, so i'm not having any luck looking up info on it, if there even was such a set
edit:
http://www.drivetrainspecialists.com...s.php?catid=25
ok, found this site that lists FMM-4209-A356
which is a FORD 9 3.56 RATIO O.E.M STYLE FORD
for $556.50
so i'm guessing it was a rarity.
please oh please help me, i'm either happy i have something rare, or ticked that i have something that won't work
351W, c6 trans, 9"
Old 10-13-2004, 02:23 PM
aka Duke of URL
Thumbs up
RG markings
PG marking
RG has 32 teeth
PG has 9 teeth
Relax, you're OK...
The stampings I.D. the gear set as B7A 4209-D, which was origionally a 3.56. It was replaced by B7AZ 4209-L (35/10) and later C9OZ 4209-A (35/10) and they were both 3.50's.
Some of the first RG were not 9" but 8.75" in dia. They progressed to 9" as time went on.
-MEL Engine Forum-
Old 10-13-2004, 03:38 PM
Muscle car fan
mounting surface diameter is only 8" on this one though, the teeth protrude wider, still it's the right thing
well that is nifty
thanks a bunch
351W, c6 trans, 9"
Old 10-13-2004, 05:35 PM
Muscle car fan
What size of a press would be required for installing the bearings
edit: some day i'll learn how to spell or hit the spell check button before posting
351W, c6 trans, 9"
