Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Possibly found the cause of my 700r4 clutch failure
Old 03-10-2013, 07:31 PM
twenglish1 twenglish1 is offline
Would the check being lodged in the plate prevent the 3 - 4 from fully engaging causing it to burn it up? It was one of the check balls located near the center of the plate, two right next to each other, both seats heavily worn, one worn so bad the ball lodged in the hole
