Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Possibly found the cause of my 700r4 clutch failure
Old 03-10-2013, 08:43 PM
twenglish1 twenglish1 is offline
What are some other places i should check for damage? i probably drove it 10 - 15 miles then decided to call a tow truck, wouldn't shift out of first, thats probably why the 3 - 4 pack was destroyed, those clutch discs were probably glowing red hot as they kept trying to engage, i was gonna try to drive it home, but it was about 30 miles away and i decided to call a tow truck instead of drive at 20 mph
Here is a picture of the two check ball holes that have the most wear, the ball was lodged in the one on the right
This second picture shows the location of the worn check ball holes, the separator plate is sitting on the valve body as it would be when assambled, the picture shows the side that mates to the case
