Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Possibly found the cause of my 700r4 clutch failure
Old 03-11-2013, 06:48 AM
dwwl dwwl is offline
Looks like your going to have to rebuild with new seperator plate. Check it out for other dameage on every (every) singe part before you rebuild. Are you going to do it yourself or hire it done? How many miles on that tranny? Like to see what those clutches look like. Like i said earllier, if its got other dameage, you could be better of getting a rebuilt one or a good use one. What ever you do, make sure you put the bigger boost valves and stronger line bias spring in. If your interested in a different tranny, take a peek at Craigs List in your area.
