Posted before need more help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2006, 11:46 PM
stoney 81ta's Avatar
Friend of mine has a 1992 dodge spirit v63L-overdrive,he's having a lot of transmission problems has replaced 3 trannys so far all used car runs good for about a week then starts locking in first gear with jumping and bucking symtons,no visible fluid loss.Any ideas what could be wrong the mileage is about 130kms on the car.Thanks all
Old 12-02-2006, 05:36 AM
Last journal entry: 65 mustang 351w efi
Is he using mopar fluid. do a google search about it. Dexron\mercon is a no-no
Old 12-02-2006, 07:08 AM
Slvrbltt yes he's using mopar fluid.
Old 12-02-2006, 09:03 AM
I once had a similar problem with a '79 El Camino......it ate trannys. I was given advice from an old mech. who told me to check the tranny mount, see if it's putting the tranny in a bind...or...make sure the dowels aren't burred, causing it to be slightly off flush with the engine block, thus putting the shaft in a bind....hope you find the problem.............
Lenny
Old 12-02-2006, 06:36 PM
Thanks Lenny ,will be checking all out tomorrow.
Old 12-02-2006, 06:49 PM
fast68's Avatar
likes chevy trucks & boobies
bucking sure sounds like en engine issue to me, but yeahmake sure the mounts are all good shape
good luck
Old 12-03-2006, 07:23 AM
Last journal entry: Bringing home the 401 Nailhead
Have the coolant lines been flushed each time the tranny was replaced?
How about the converter? Replaced or same one?
Old 12-03-2006, 03:56 PM
airworld2's Avatar
depend on each transmission failure, could be cooler in radiator stop up and planet failure would result. or trans isn't the problem and wiring is, you need to let someone look at the car to determine what your trouble may be guessing isn't getting the job done.
airworld2
Old 12-03-2006, 04:15 PM
Friend of mine has a 1992 dodge spirit v63L-overdrive,he's having a lot of transmission problems has replaced 3 trans.
Sounds to me like he needs another car ...
cheaper to JUNK HIS and buy something else ...
Old 12-04-2006, 01:20 AM
tranny
I always flush the lines when I change filters, or drop the pan to do anything.... cheap insurance. Check for wear on the converter, see if by some chance theres any evidence of friction, but I used the same one..on the other hand, if you'll have peace of mind, and happen to know where you can pick one up........
