Postive Valve Seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2003, 11:02 PM
Postive Valve Seals
I was just reading this in another post and had a couple questions.
Jmark:
The redish deposits are normal with todays gas. If money is short, have a machine shop ck the guides and seals. O-ring and umbrella seals are things of the past. Positive seals are much better and will do a good job even with increased stem to guide clearances. The pistons and rings may last a while longer, but its pretty much a crap shoot.
I'm not very familiar with different types of valve seals I was just wondering what the difference between o-ring seals, umbrella seals, and positive pressure seals were. What are the disadvantages/advantages of each were, and if you had to do anything special to the heads to install positive pressure seals. Just thought I'd ask, thanks.
Old 09-08-2003, 09:43 AM
SAE Member, ASE Master Cert.
The premium quality positive seals and made from Teflon and are white in color, avoid any inexpensive subsitutes. There are also some positive seals made from rubber with a Teflon insert that work fairly well. The main thing about a positive seal is that they fit snuggly on the valve guide. In most cases the heads need to be disassembled and the guides machined for the positive seals. It is a very simple machining operation and any high performance machine shop should have the correct cutters.
