Pot Metal Welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2004, 07:34 PM
New Member
Question Pot Metal Welding
I am planning on cutting down a set of 92 Caddy taillights and I was wondering if it is possible to weld on the pot metal trim. If welding wont work, is there any other method I could use to put the peices back together?
Old 02-26-2004, 07:49 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
I think brazing that stuff works better.
Correct me if I'm wrong.
Old 02-27-2004, 08:51 AM
Hot Rod Hellion's Avatar
You're right. No way to weld that stuff; brazing or soldering would be the only way. But there are some really cheap rod alloys out there, that you should stay away from. (like most of the miracle aluma-weld crap found at swap meets and flea markets)
Here is a good place to get good rod... (check out the rest of this site too, the information is incredible)
http://tinmantech.com/html/aluminum_..._brazing_.html
Old 02-27-2004, 05:26 PM
Frisco's Avatar
Glad To Be Here
I will be very interested in the answers to your question.
I am not a welder, but I have always been under the impression that "pot metal" could not be welded, brazed, soldered or otherwise repaired except with epoxy or a similar method.
However, I did a search and found this site. It may be of interest to you.
http://muggyweld.com/potmetal.html
Old 02-27-2004, 06:02 PM
That muggy weld is what I'm talking about when I say flea market miracle weld... It might work fine, but I'm skeptical. Keep in mind that it's not really welding the metal... it's a solder or a braze depending on the temperature used. Its only considered a weld if it melts the parent metal along with the rod. A genuine weld is not possible with pot metal.
But whatever product you do decide to use, please come back to this thread and tell us what results you have!
Old 03-05-2004, 09:00 PM
New Member
thanks for your help guys. I think I am going to try the muggyweld approach. I know the stuff might not be the best out there but the piece I am working on will not be put under any any stress or pressure so I feel that it will work out fine. Now that I got that problem solved, I have another question. Does any one know of a company that make a shorter lens for these cut down mouldings? I thought about a DIY approach but I think that might be a little outta my leauge. Thanks again guys
Old 03-05-2004, 09:31 PM
walt's Avatar
No Sweat
I weld pot metal all of the time. I weld it with a Heli-arc and pot metal rod That I purchased from my local welding supply house. The most important thing to do is to strip the chrome off first or it will be imposable to weld. If the part is very fragile with fine details you may have to support it in a bed of lime while welding it. I'm not sure because I've never tried it but I don't see why you can't gas weld it if you support it. Pot metal is pure zinc which has a very low melting point, That's why it is used for trim castings. it flows into molds very well. So if you make a mold from lime or VERY fine sand you can simply support the cut-down part and remelt it with a torch.
Old 03-05-2004, 09:36 PM
84layinframe,
I have taught metal shop for about 30 years and the only way I have been able to repair "pot" metal items is by soldering them.
These metals seem to have a high content of lead so soldering does the trick.
I do not use the comon 50/50 solder I use 40/60 solder. It melts at a very low temprature and will do just what you want. I also use paste flux to keep everything clean.
Good Luck
Scholman
Old 01-20-2007, 11:04 AM
sparkplug1's Avatar
chrome plating
Hello just wondering if all of these materials are able to be chrome plated after the pot meatal is fixed? Thankyou Randy
Old 01-20-2007, 11:44 AM
As the man said these pieces are a zinc alloy used for the ease of casting and ability to retain fine detail. Repairs done with compatible material are platable.
No one will ever make shortened or otherwise custom lenses for any light except that they also offer the correct side housing to hold them. They would never be able to exactly match a home-done cut job.
Old 07-03-2013, 10:32 PM
Depending on the bond, adhesion,weld or whatever means you do it depends if it will chrome as well as the melting point of what you did.... I've tried the swapmeet set crap and it doesn't chrome - they have a metal epoxy that works pretty well if you are welding, soldering or brazing skills are non existent or not to par, and you can work with it easy and you have to grind or file the excess of like real metal and its chrome able
Old 07-04-2013, 06:46 AM
Wiki Edits: 27
pot metal welding
The UVU streed rod Instructor said that he tig welded some of the pot metal trim on a sectioned 40 Ford convert on display in the main hallway in the automotive -diesel wing at the college. Charlie,one of the grandpa perpetual students, whose custom trike usually shows up when I post, welded some of the Space shuttle-satalite parts and said that he used to use an "incubator" Box . The parts and torch, rods were inside the box, like a small sand blaster. they would evacuate the box then fill with argon, then make X ray quality welds. I don't know if you need a welder with AC balance, Pulse and Variable Frequency to make good welds. If I ever find time I might try with my Lincoln 255 Tig machine, but It doesn't have Freq. adjust.
