pouring paints - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2006, 04:55 PM
pouring paints
OK, this may be the stupidest question of the year, but does any one have any tips, secrets when pouring paints, or primers from a gallon can into the mixing cup, heres my dilemma, I open a brand new can of say,, primer and I pour it in the mixing cup, but then here comes bout a pint running down the side of the can, is there a easier way , as you know this stuff is expensive to waste..
Old 01-09-2006, 04:58 PM
Check you tips of the day. Put a piece of two inch masking tape around the edge of the can, so part of it goes past the top to use as a pour spout. You may also look for a pour spout at your supplier. They make some that snap on the can. Don't forget to punch some holes in the groove on the top of the can, so any paint that gets into the groove will drain back into the can.
Old 01-09-2006, 05:12 PM
I do have the spout thing, Its ok, still makes a little mess, I like the punch holes, Ill try that, thanks...
Old 01-10-2006, 06:01 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I usually pour my gallon of paint off into quart cans right after
mixxing it real good. It lasts better for me that way and keeps it more
consistent. But a gallon last me a long time, I only do small panel repairs.
The tape around the lip works real good.
Old 01-10-2006, 09:55 AM
I can tell you what NOT to do! I thought it would be a good idea to seperate the gallon into 4 qt containers so I used 4 clean Mason type glass jars, hey they pour clean, easy to seal and you can see the level inside. I still have that big red spot on the garage floor right in front of the door
Old 01-10-2006, 11:29 AM
Bad Rat's Avatar
Last journal entry: SACRAMENTO AUTORAMA 02/05
Wiki Edits: 2
[QUOTE=oldred I still have that big red spot on the garage floor right in front of the door [/QUOTE]
NOW we know how you got your name,,
What paints do not have iso-cyanates? Safer alternatives? FrankR Body - Exterior 8 12-03-2005 11:36 AM
who paints ghost flames in northern california? batman09 Body - Exterior 5 11-09-2004 07:32 AM
Matrix Paints ChrisMiddleron Body - Exterior 0 06-26-2004 07:22 PM
lacquer paints availible in Arizona bigwildgrin Body - Exterior 8 11-22-2003 06:34 PM
Coolant pouring into cylinder and oil pan Johnny Bravo Engine 2 09-06-2001 10:34 PM
