Powder coat curing problem
I have been having trouble with orange peel on large flat surfaces when powder coating. Am getting a nice covering when spraying and the item to be sprayed is clean. Have a good dry air supply. Getting a nice gloss but with slight peel. Using a small toaster oven. Curved surfaces look OK, but the peel might just be a lot less noticeable on curves. Temp problem? Any suggestions would sure helpful.
You will always get a bit of orange peel, and some colours are worse than others. Try putting on the powder a bit thicker if you can. Unfortunately if you're using a cheapy gun, the power supply will prevent you from building the powder to thick.
You could try "hot coating" !! Pre heat your part to about 220 degrees, then put the powder on then bake as usual. This may allow you to put more poeder on. Dan |
Thanks Dan, I'm gonna' try that this mornin'. I'll let you know.
Tried preheat and heavier coating. A little better, thanks. I think I am expecting too much from this setup. I do some custom painting on bikes and I was looking for that finish. I don't think I'm gonna get it, especially on this 1/8 " aluminum sheet. Thanks for your help.
| Curing Lamps for Powder Coating Applications | lt1silverhawk | Garage - Tools | 16 | 06-05-2011 05:48 PM |
| powder coat | jasrking | Body - Exterior | 6 | 06-10-2008 05:15 PM |
| Powder coat | TEXAS'55 | Hotrodding Basics | 1 | 02-14-2007 10:39 PM |
| powder coat | rlvirago | Engine | 4 | 07-12-2006 08:15 AM |
| UV Powder coats- "Powder coat Bill". | BarryK | Body - Exterior | 1 | 05-17-2005 08:54 AM |
