Powder Coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2007, 12:16 PM
jor jor is offline
Powder Coating
Anybody do any powder coating? I picked up a powder coating oven and gun (the Eastwood starter deal) at a garage sale. It looks pretty simple - just clean, spray and cook. The only problem is the oven measures only about 17X17X20. About the biggest thing I could get in there would be an intake manifold and then I would have to put it in diagonally. Anyhow, I see that Eastwood sells some infra-red curing lamps for the larger items. I'm wondering if these would be worth buying. If not, what would be? I'm thinking in terms of a radiator support, inner fender, like that. Thanks.
jor
Old 01-08-2007, 12:48 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
I bought a used electric oven. But it still gets small at times.
Old 01-08-2007, 01:32 PM
Yup, I've got the Eastwood kit and an oven........Use it for brackets, pulleys, etc. Haven't tried anything big yet.
Old 01-08-2007, 01:47 PM
jor jor is offline
Buster, do you have the IR lights too, or just the oven?
jor
Old 01-08-2007, 02:12 PM
I just have the oven..........have never heard of results from the lights..........and don't really want to have to store them when not in use. Although, it would be kinda cool to do my own frame, huh?
Old 01-08-2007, 03:49 PM
Bare Knuckles Champ
Last journal entry: Made a wrench...
Built a large oven. Looks kinda like a safe. Propane burners at the bottom. 6'x4'x4'. Put oven temp guages in center of door about 1/4 way from top and bottom. Insulated with 1" insulating foam with reflective sheet. Will try to post pics.
Had used oven before, but it was just too restrictive on size, and rack system was a pita.
Old 01-08-2007, 09:46 PM
cboy's Avatar
Last journal entry: Finished
Yes, you can build your own oven to basically any size and shape you need. Most guys then put electric oven heating elements in them to provide the heat source. If you google something like "build powder coating over" you should come up with some sites with plans, drawings and pics.
Always learning...and sharing what I've learned.
Old 01-09-2007, 09:07 AM
gator412's Avatar
Here is a forum on building power coating ovens.
http://forum.caswellplating.com/forumdisplay.php?f=18
Old 01-16-2007, 10:32 AM
Cheep Way
Hi I Am Getting Ready To Build My Oven Got Rid Of Old Junk Truck At Salvage Place And While I Was Talking To The Man I Saw Some Trash Bin,s And Guess What Just Right ,,weighting For Him To Bring It So I Can Get Started On It It Is About 8x8x6 Tall I Will Take Photos As I Go If Any One Wants To See Tim
Old 01-16-2007, 11:23 AM
jor jor is offline
Yea, please document your whole building project if you can. I and probably others, would be very interested in seeing it. Thanks.
jor
Old 01-16-2007, 05:29 PM
cboy's Avatar
Tim,
I second that. I'm particularly interested in the documentation of an over that large. Most of the home build ones I've seen on the web are quite a bit smaller. So yours will be of real interest. Probably best to post it in the Garage/Tools Forum when you get ready with some pics.
Primer before powder coating? gsrokmix Body - Exterior 19 02-06-2013 01:53 PM
Powder Coating chuckbell8 Introduce Yourself 2 11-04-2006 09:25 AM
Powder coating Engine Chadwick Engine 4 11-26-2005 08:31 PM
powder coating auot body ELECTROBE Body - Exterior 0 07-24-2004 12:09 AM
Powder coating vs. chrome Busted Knuckles Body - Exterior 13 01-21-2004 01:32 PM
