powder coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 03:08 PM
powder coating
is powder coating supposed to be solvent resistent l thought it was supposed to be. had my tunnel ram done. and while it was under my wrok bench i must have splashed a few drops of paint thinner while cleaning a pin stripe brush left like 2or 3 dots but it took the silver chome like finish off
Old 04-27-2011, 10:56 PM
hp246's Avatar
If you intentionally want to remove powder, it is a real b*t*h to remove. Requres a special solvent or a lot of patience. That said, thinners and other paint solvents will damage a powder coat surface.
Old 04-28-2011, 07:49 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Yea, it's not indestructable. Regular paint stripper will remove it. As been said, other solvents can damage it.
Old 04-28-2011, 09:13 PM
Last journal entry: Suggestions worth sharing
If the powder coating on your intake manifold is a silver "chrome-look" finish, then unless it is clear coated, the finish will likely be inherently lower in solvent resistance than other powder coatings, at least as far as color retention is concerned. This is because in order to achieve the bright look to mimic chrome, leafing aluminum pigments are probably used, which largely lay on top of the surface of the powder finish. This layer of leafing aluminum can be much more sensitive to solvent attack or attack by caustic cleaners than are other powder coatings that are not pigmented with leafing aluminums.
Unfortunately, this type of finish also suffers from the drawback that when they are clear coated, much of that desired bright appearance is also lost. It becomes almost a catch-22 situation. One takes their choice between a less appealing appearance if clear coated, versus reduced long-term resistance to discoloration by solvents or cleaners if left without a clear coat.
Powder Coating alcher14_82 Hotrodding Basics 13 04-13-2008 07:15 AM
Powder Coating jor Body - Exterior 10 01-16-2007 06:29 PM
Powder Coating chuckbell8 Introduce Yourself 2 11-04-2006 10:25 AM
Powder coating pepi General Rodding Tech 14 09-29-2006 08:40 PM
Powder Coating street rodder 1937 Engine 23 10-20-2003 04:24 PM
