Powder coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 10:23 PM
Powder coating
What would happen if you first port match your intake manifold and then, power coated the inside runners? If you're worried about atomizing the fuel as it flows through the manifold, use a wrinkle finish powder coating.
Old 01-23-2012, 10:28 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What would be the benefit??
Semper Fi
Old 01-24-2012, 09:19 AM
It would be like polishing the runners, smoother flow to the cylinder head. It would also fill any imperfection inside the manifold. And if I understand it right, keep the fuel air mixture cooler.
Old 01-24-2012, 09:23 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
wouldnt help anything that I know of
the gas would slowly eat it away anyway, over a few years
just curious, what intake is it?
Old 01-24-2012, 09:37 AM
I haven't done this just for the reason you mentioned. But the manifold is this chinese piece I got from Pro Comp. It was cheap so I'm not worried if I screw it up. The thing was bad when I opened the box. None of the ports matched so I port matched everything, cleaned up the runners and plenum too, poor casting. On one port I had to epoxy fill because the opening was too high and was to far into the gasket for my liking. It looks much better now and then I wondered about powder coating the inside.
Old 01-24-2012, 10:29 AM
If the solvent (gasoline) degrades the powdercoating and this 'sludge' ends up in your crankcase and then gums up...everything or hangs a valve open...hey if you bought the junk intake to begin with...I hope you didn't invest much in the motor. Extrude Honing is a better option. YMMV
& matts38chev
by the time you pay to have it powder coated, you could have bought an edelbrock air gap
Old 01-24-2012, 10:48 AM
& matts38chev
I would just run it the way it is, or even better, try and sell it to help pay for a better intake
Old 01-24-2012, 11:01 AM
I actually have 3 manifolds for my engine. The cheap chinese junk that I'm playing with, and Edelbrock RPM air gap and a Edelbrock street tunnel ram which is on the engine now. Don't know if my profile picture came up.
Old 01-24-2012, 12:08 PM
& matts38chev
very good
powder coating hemantwalzade Garage - Tools 4 01-22-2012 08:00 PM
Powder Coating jor Body - Exterior 10 01-16-2007 06:29 PM
Powder Coating chuckbell8 Introduce Yourself 2 11-04-2006 10:25 AM
Powder coating pepi General Rodding Tech 14 09-29-2006 08:40 PM
Powder coating tip MiMAX Body - Exterior 8 05-12-2006 02:23 PM
