Powder Coating a Frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2008, 05:58 AM
Hi,
I need to have my frame powder coated.
Is there any body filler material that can be used that will withstand the heat of the oven?
Also, how does Epoxy paint compare with the durability of powder coat.
The frame will be black in color.
Thank you.............
Old 05-18-2008, 08:56 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I have heard of people using JB weld for small areas needing filler. I think that stuff is good for like 500 or 600 degrees F.
Old 05-19-2008, 04:25 PM
Irelands child's Avatar
http://www.corrotherm.com/ct-334.htm for filler
This is a powder coated chassis:
No comparison to epoxy IMO. I've dropped fasteners, wrenches, dragged car parts across it with nothing more then a surface scratch that was easily polished out. The one minor downfall is that there MAY be some orange peel.
Dave W
Irelands child
Old 05-19-2008, 10:41 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Another product:
http://www.alvinproducts.com/Products/Products.asp?id=2
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 05-20-2008, 12:02 AM
Originally Posted by powerplay13
Hi,
If you want that frame right, epoxy it, then if you scratch it you can touch it up.
Powder coating has its place, and a lot of times better then paint, but not for a frame.
To many drawbacks to powder coat.
Like he says the orange peel, then you have to drill out your holes or use a carbide burr and hope you don't chip it, if you stone chip it how do you fill the hole and match the powder coat.
If its going to be driven, things are going to happen, if you want it on the dead ready, you have to go over those areas after a road trip,
Anyway fill and sand and dp epoxy. Figure about 400 to 500 hours on the chassis if you do all the pockets and inside the frame rails.
Rob
http://www.1969supersport.com
Old 05-20-2008, 07:24 PM
I've done them both ways. Powdercoat is real nice but i dont know if it has the corrosion protection quality of epoxy. Touch up is tough too.Heres my subframe i had powdercoated. i had a cable slip when i was loading it on a trailer and it scratched the frame in front of the A-arm. If it was epoxy i could just spot it in. Guess it depends on how picky you are. Both are good options.
Old 08-08-2009, 05:04 PM
78ELK51GMC's Avatar
Last journal entry: Starting to put back together
Powder coating a frame
I just had my frame coated in silver, it came out real nice. I left it out for a couple of weeks, it rained and now I have 3 or 4 spots that are turning brown from rust. These are very small spots and where the frame is not flat, like weld spots. The coater said he did t right and says because it was out in rain. I disagree, but he is not willing to correct it. He suggested I silicone the spots. Just something to consider when making the choice. If I knew this, I would have painted it.
Old 08-08-2009, 05:48 PM
Rag top bird's Avatar
Hot rods are still the king
Hi,
If you are looking for a OEM look I would go with the epoxy that is what we use on all of our cars and is esay to spot in if nessary
Powder Coating Aluminum Intake budthespud Body - Exterior 11 01-22-2008 05:12 AM
Frame powder coating color question. schnitz Body - Exterior 6 01-19-2006 02:42 PM
cheap powder coating? scheetz93 Body - Exterior 12 11-29-2005 08:05 PM
Powder coating brake servo Jag Daddy Suspension - Brakes - Steering 1 04-15-2003 06:36 AM
high temp paint or powder coating headders??? 1941 studebaker Transmission - Rearend 3 12-14-2002 08:42 PM
