Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powder coating @ home: mess & smell?
Old 03-19-2008, 08:54 AM
techron techron is offline
hey 66 chevy, i use the HF gun too. it's the same as eastwoods but cheaper. try a kitchen oven instead of a toaster oven. you will love it. the only thing that makes me mad is you can't do really big parts like rear axel housings or tube axels--they won't fit in the oven...
here is a tip: preheat big parts in the oven before you spray the powder on. make sure the parts are clean (i usually bead blast them first) ...
EDIT: also i buy my powders, hi-temp tape, hi-temp plugs off ebay. there is a seller in utah (can't remember the name) that sells good stuff for cheap. just search (powdercoat) on ebay...
