Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Powder coating @ home: mess & smell?
Old 03-19-2008, 12:12 PM
nissan's Avatar
nissan nissan is offline
Last journal entry: 1930 chevy ratrod pick-up
powdercoating
keep the ground wire hooked up when moving the item into the oven,hook the other end of the ground to the inside of the oven then ground the oven. to build a larger oven cut up two ovens,or build from scrach and use oven elements or infrared lights.I worked 4 years in this industry there is a lot of info about building your own oven,good luck.
