Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - powder coating W/ Eastwood kit
Old 02-21-2002, 05:50 PM
jwcnj45's Avatar
jwcnj45 jwcnj45 is offline
I tried the Eastwood kit on some suspension parts a while back. The results were ok but nothing to rave about. We ended up using an acrylic urethane paint on the remainder of the parts as it was much easier to use and the results were just as good. Remember you must heat the parts to 400 degrees in order for the powder coat to flow out. Unless you have a good IR lamp set up or an old electric oven, not the one in your house,it's not worth trying.
