Powdercoat Q... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2008, 09:04 PM
S10xGN's Avatar
Gotta love a turbo!
Powdercoat Q...
Hi All,
Can polished aluminum be clear-powdercoated? Will the polished surface have enough "tooth" to hold on to? How about a mix of polished alum and a good quality single stage urethane paint? IIRC, 400 is what's needed to melt the powder and the paint should be OK there, at least for the short duration needed to cure. Opinions?
Thanks!
Russ
Old 10-27-2008, 09:26 PM
Stovebolter's Avatar
36 Chevy Low Cab
Last journal entry: C4 IRS
You might check out Eastwoods clears. I work with a guy that coats all of his aluminum wheels with the stuff and he swears by it.
Dave G
Old 10-28-2008, 06:41 AM
cboy's Avatar
Last journal entry: Finished
Here's an aluminum intake I polished and clear powdercoated a couple of years ago. I took a "before and after" to show that the clear does dull the finish just a bit...so be prepared for that.
Also, after a couple of years use I do have some minor checking in the finish. I did the powder coating with my Eastwood hobby kit so I'm assuming the checking is a result of my application or baking procedure. Other than that I'm satisfied with the way it turned out.
Always learning...and sharing what I've learned.
Old 10-28-2008, 06:55 AM
36 Chevy Low Cab
Cboy, how do you like the Eastwood stuff compared to other vendors? I was thinking about powdercoating my flex conduit for my headlights black. Wondering about chipping of the stainless steel stuff.
Dave G
Old 10-28-2008, 08:14 AM
cboy's Avatar
Originally Posted by Stovebolter
...Cboy, how do you like the Eastwood stuff compared to other vendors? I was thinking about powdercoating my flex conduit...
My powder coating experience is limited to using only Eastwood products, their gun and their powder. So I can't compare vendors or other manufacturers. There are some REAL powder coating pros here on the board...so hopefully one or more of them will chime in.
Regarding the flex conduit, also no direct experience. One thing to keep in mind, however, is that powder coating is thicker than paint. So there might even be a question of limited flexibility once the coating was applied, in addition to the potential chipping and scratching. Also, I'd be a little concerned that since you are considering black, that once you started to flex the thing after coating that you might see little slivers of the bright stainless down in the flex joints that don't get coated.
You might end up just having to experiment on this one to see what happens. Maybe you could find some cheaper flex tubing than stainless to try it out on. Post up any results if you try it.
Old 10-29-2008, 04:38 AM
S10xGN's Avatar
Gotta love a turbo!
I was mainly concerned to see if the powdercoat would stick to a polished surface, looks like it will!
Russ
Painting over powdercoat?? texastomeh Body - Exterior 20 05-22-2007 08:05 AM
Paint or powdercoat? tfeverfred Hotrodders' Lounge 23 04-13-2007 10:47 PM
Stripping powdercoat off factory wheels Arrowhead Body - Exterior 4 02-22-2007 09:09 AM
How to remove clear powdercoat from intake drewhelm General Rodding Tech 3 02-06-2006 06:17 AM
matching paint color to powdercoat color powerrodsmike Body - Exterior 4 12-11-2005 07:01 PM
