Powdercoated hard lines. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2006, 08:27 PM
I see that JEGS offers a 25' coil of powdercoated brake line.
My question to you is how bendable is this stuff?
Not the line itself so much as the powdercoat, will it be cracking and flaking if I try to bend/flare it?
Old 08-11-2006, 07:49 AM
bigjoe's Avatar
Last journal entry: Steering box reversal
I don't know about the Jegs stuff, but here at NAPA we have a similar product called "polyarmor" brake line. It has a coating on it that resists all sorts of ails. It actually helps the line resist kinking, so it's MUCH easier to work with. You can make some extremely tight bends with it compared to regular line.
Joe
Old 08-11-2006, 10:27 AM
What size lengths do they offer at napa, and price?
Old 08-12-2006, 03:21 PM
bigjoe's Avatar
I comes in increments from 10" to 60" in 10" increments, and I've heard from the factory reps that it will soon be available in 25' coils. It isn't much more expensive than regular lines. Anywhere from 2 to 6 dollars depending on the size and diameter. It is available in 3/16, 1/4, and 5/16".
Old 08-12-2006, 07:24 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Don't know about the brake lines specifically but my guess is they are very flexible and durable. I powder coat everything on a car that I can and the stuff bonds so well to steel that you can literally do body work w/o flaking it off.
info transfer form old hard drive to new ChevelleSS_LS6 Hotrodders' Lounge 6 03-02-2005 04:06 PM
Hard lessons being learned here... please help Cracker Red Body - Exterior 2 12-31-2004 05:21 PM
Kerry and jobs overseas... lluciano77 Hotrodders' Lounge 9 12-25-2004 08:59 PM
brake lines too short after suspension rebuild FiveFeezy Suspension - Brakes - Steering 4 03-10-2004 09:25 PM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 06:10 PM
