Powdercoating a frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2014, 04:45 PM
Because of chips, peeling, and other problems with powder coat, I'm a little hesitant to use it on a frame.
Has anyone had a bad experience with powder coating a frame?
Old 08-05-2014, 09:15 PM
hp246's Avatar
I've used powdercoat, though not on a frame. I live on a dirt road, and the powder coat parts I've used get a sand blast treatment from the road on a regular basis. I've had no problems with chipping. I have used POR 15 on a frame and was happy, but if I had my druthers, I'd use powdercoat. If you had a problem with peeling and chipping, I would bet the surface wasn't prepped properly.
Old 08-06-2014, 01:44 PM
33Willys77's Avatar
Done several with powdercoat. Its good and strong, but yes it can also chip - so can paint. Have some single stage paint (same color) available for touch ups. Had good luck with powdercoating - and its cheaper than paint too.
Old 08-06-2014, 02:27 PM
454 Rattler's Avatar
NEVER SATISFIED !!
33WILLYS77 says powdercoat is cheaper than paint. Is that right ? I never heard that before.
454 RATTLER
Old 08-06-2014, 03:44 PM
Banned
had my frame for the 27 blasted & powder coated in 08 and it was $350. It has held up perfect!! the place is about 5 miles from me , they picked it up and dropped it off also.
Old 08-06-2014, 03:57 PM
Irelands child's Avatar
My '31 was media blasted and powder coated about 8 years ago. Stones, dropped wrenches and other things haven't hurt it a bit - not a chip that I've seen yet.
This is the day I got it back:
And a small part of it about 5 months ago when I freshened the driveline and steering
Irelands child
Old 08-06-2014, 04:25 PM
33Willys77's Avatar
I had a complete frame, rearend, complete front parts, motor mounts, trans mount, and other brackets done at a local place. They blasted and coated everything for $325. Yes, it is cheaper and I didn't have to do it.
Old 08-07-2014, 05:12 AM
Yes, it's cheaper. I got a price of $600 (northern nj) to sand blast and powder coat.
Thanks, I was worried about stone chips and such. I have a friend who is giving me powder coating horror stories, which I don't buy.
Do you think that galvanizing the frame is necessary under the powdercoat? That's about $300.
Old 08-07-2014, 08:14 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
I've never heard of galvanizing it first. It doesn't seem compatible as they both need heat, the powder to cure and the galvanizing to melt. Wouldn't the galvanizing run under the powder while curing ??? or is it a cold coating ??
Old 08-08-2014, 02:20 PM
hp246's Avatar
Galvanizing is done at about 850 degrees with molten zinc. Powdercoating is baked at about 400 degrees. I don't think baking the Powdercoating would affect the zinc.
Old 08-08-2014, 06:25 PM
Unless the car is going to be driven in the ocean surf, that's really excessive. Then there's the situation that if you want to weld a forgotten bracket on, the zinc coating fumes will make you very sick where PC can be ground off then touched up with a like color paint. Oh yeah, media blast and PC that frame I show above along with a loose few brackets, $400
Irelands child
Old 08-15-2014, 09:28 PM
Two separate processes, days apart. It can be done.
Old 08-15-2014, 09:31 PM
Thanks. Galvanizing is overkill.
The local shop does really nice work, he gave me a number of $600.
Old 08-16-2014, 10:43 AM
Shelby1's Avatar
Steel Dreams
Power coating a frame
Years back when I was still involved in sprint car racing we had the cars frame that we were running at the time power coated a bright gloss white, I was on that crew for two years and when winter time came and racing stopped we would tear the car down for a good going over we never found any thing wrong with the power coat. And i can tell you that car saw way more abuse from the crappy tracks that we ran on than any thing a street driven car would ever see.....so yes IMHO it does work with no problems.
Kenny
You might do all you say you can do........but first you have to catch me G-man
Powdercoating pulleys NOBLNG Engine 2 12-13-2010 04:59 PM
Powdercoating Headers?? 72chevyC/10 Engine 9 10-27-2005 10:59 AM
Powdercoating at home.... ZeeksChopShop Body - Exterior 2 02-14-2005 03:31 PM
powdercoating madhat Body - Exterior 37 08-10-2004 06:00 PM
POWDERCOATING mitmaks Body - Exterior 13 11-19-2003 01:46 PM
