Powdercoating Leaf spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2011, 07:04 PM
Can I strip and powdercoat my leaf spring, or is this not advised as the blades slide against each other?
The blades in my spring have rubber buttons at the end of them, so it's not the actual blades rubbing against each other
Does this make any difference?
What's the best approach to fishing my spring?
Old 01-14-2011, 07:07 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
yes you can, it will wear through where they rub after a while
Old 01-14-2011, 07:20 PM
Powder Coating
Remember Powder Coating Is A Heat Based Process So The Metal Is The Only Thing That Can Go Into The Oven...no Rubber, Plastic, Etc.
And Because These Leafs Will Rubb Against Each Other You Will Have Chipping. You Would Be Better Served By Doing A Good Paint Job On Them Assembled.
Old 01-14-2011, 07:39 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Painting assembled leads only to quicker rusting misery.
Powder coating will take alot longer to get there.
BTW, it takes longer to type if you capitalize every word.
Old 01-14-2011, 08:13 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
[QUOTE=ant_8u]Can I strip and powdercoat my leaf spring, or is this not advised as the blades slide against each other?
You must have a pretty big oven if your going to do them yourself.
I would go with a Shop that can sand blast them and P/C them properly. Stripping the springs down to their barest form would be a sizable job, as well as the re-assembly. Don't forget the spring clamps, shackles, and hangers.
Old 01-15-2011, 10:30 AM
ogre's Avatar
the 'Duracell Project'
ant
you could use anti-squeak in between the leafs
i painted my springs with por15 and installed the anti-squeak in between each leaf
it came in a roll and is designed for leaf springs
i tried to find a link but failed
Old 01-15-2011, 11:02 AM
I have a set of Eaton (Detroit) Rod-Ride rear springs, and I called them to ask about disassembly and painting or powder coat, and they did not want me to take the springs apart, and recommended that I just get a decent quality paint (POR, Rustoleum, etc.) and just coat them a couple of times before putting on the vehicle. They said to touch up periodically if any rust starts to show around the edges. Springs are painted and on, but car is still in the build stage!
G-Willys
leaf spring help studebaker transtar Suspension - Brakes - Steering 2 03-25-2010 05:55 PM
Need Help With Leaf Spring Set Up brad11957 Suspension - Brakes - Steering 1 10-29-2006 01:10 AM
leaf spring Pepsi Suspension - Brakes - Steering 4 10-17-2006 05:55 PM
leaf spring probs bigtim Suspension - Brakes - Steering 2 06-25-2006 09:17 PM
Leaf spring help ffcagle34 Suspension - Brakes - Steering 3 08-22-2003 10:37 AM
