Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power booster
Thread: power booster
Old 05-11-2013, 09:13 AM
1badLemans's Avatar
1badLemans 1badLemans is offline
Yes you should be able to bolt up a booster just make sure you have the correct bracket for the booster and that the booster will bolt up with the master cylinder. Also you might have to adjust the length of your brake lines depending on the size of booster you choose. Finally make sure your engine makes enough vacuum to operate a booster. Good luck
