power booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 09:46 AM
power booster
I have a 40 ford coupe with 4 wheel disc brakes that are manual with the master cyl under the floor. I would like to convert to power assist. Can i just add a power booster to the master cyl thats already there? Any info would be greatly appreciated. Thanks Atlas
Old 05-11-2013, 10:13 AM
1badLemans's Avatar
Yes you should be able to bolt up a booster just make sure you have the correct bracket for the booster and that the booster will bolt up with the master cylinder. Also you might have to adjust the length of your brake lines depending on the size of booster you choose. Finally make sure your engine makes enough vacuum to operate a booster. Good luck
Old 05-12-2013, 09:52 AM
booster
thanks i will give it a try
mc/power booster apache10 Suspension - Brakes - Steering 6 07-18-2007 12:35 AM
power booster bob eaton Suspension - Brakes - Steering 4 12-11-2006 10:45 PM
Power Booster torinotroy Suspension - Brakes - Steering 3 09-03-2006 09:32 PM
power brake booster stanjr41 Suspension - Brakes - Steering 12 10-18-2005 01:27 PM
dual power booster bb53f100 Suspension - Brakes - Steering 4 01-30-2004 02:32 PM
