Power Booster for Disc/Disc Conversion in '64 Impal - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2012, 08:27 PM
I have a '64 Impala w/factory power drum brakes. I want to convert to power 4-wheel disc brakes. I purchased an 8" dual diaphragm booster kit w/dual master cylinder from Performance Online to start the conversion. The booster/master cylinder measures 16.5 inches from the front of the master cylinder to the back of the mounting bracket (about 3" from the back of the alternator). In addition, the booster rests just above the engine dipstick, so close that it can't be pulled out. I heard that some company makes a streamline 9" single diaphragm booster that doesn't extend as far from the firewall. Does anyone out there know the particulars of this booster? Will a single diaphragm booster work in a disc/disc application? Has anyone successfully accomplished this conversion in a 63-64 Impala? Are pre-formed lines available for the dual master cylinder in a '64 Impala? I appreciate any help you can offer.
Old 08-05-2012, 09:14 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hmmm ... I know that the hydroboost system from the same company is quite a bit more expensive, but it's quite small. It's also a very powerful system that works great on cammed-up engines with low vacuum.
Classic performance also makes an offset booster (over 2" and up 1") that may give you the clearance that you need.
Power Disc Brakes vs. Brake booster allclassicsbefore70 Suspension - Brakes - Steering 5 09-24-2011 02:08 PM
1966 nova power disc brake conversion jim cass Suspension - Brakes - Steering 2 04-26-2009 09:38 AM
Disc brakes without power booster? KNanthrup Suspension - Brakes - Steering 10 01-10-2008 09:02 PM
MC for disc/disc with 7" booster? oldguy829 Suspension - Brakes - Steering 4 05-14-2007 05:12 PM
'68 Camaro front brake/disc power conversion problems nathanlburns Suspension - Brakes - Steering 9 05-14-2004 08:22 AM
