power brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2005, 05:51 PM
PaulNJ53Ford's Avatar
power brake booster
I have a 1953 ford customline . i put disc brakes in the front and rear. the front are granada disc and the rear are mark II disc. i have a 1986 mustang gt i am breaking up . can i use the power brake booster from this car? it is a 8 '' booster. and what master cylinder can i use ? i don't think i could use the master cylinder from the mustang because it has rear drum brakes. also where can i get brake lines and hoses for this project? thanks for any info paul.
Old 10-16-2005, 09:37 PM
If you can figure out a way to mount the booster and hook it up to your pedal, more power to you. The master will have to be changed to a disc/disc master and you'll need to find either a disc/disc fixed proportioning valve or plumb in an adjustable proportioning valve to your rear brake side.
Look on ebay for guys that will make you custom flexable brake lines, I just had a set made up for my Torino I converted to front discs. The hard lines just bend em up yourself...
Old 03-29-2006, 07:11 PM
Hydroboost Systems
Have You Looked At The Hydroboost? They Are Small And Powerful. They Can Deliver The Volume And Pressure (up To 2000psi) To Work 2 Disc Or 4 Disc Brakes And No Vacuum Required! They Run Off Of Power Steering Pump Pressure. The Pedal Pressure Is Light And Comfortable Feeling. We Have A Hanging Pedal Assy, Or If Your Master Is On The Firewall, We Ahve The Mounting Bracket Ready To Go. Check Them Out At "powerbrakesonline.com" These Things Really Work. 800 504 1060
Brake booster M&M Suspension - Brakes - Steering 5 03-31-2006 01:56 PM
power brake booster stanjr41 Suspension - Brakes - Steering 12 10-18-2005 12:27 PM
Power Booster on Drums? beetle9 Suspension - Brakes - Steering 3 04-27-2003 04:43 PM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 01:36 PM
brake booster 34Plymouth Suspension - Brakes - Steering 3 02-14-2002 08:53 PM
