power brake booster and master cylinder ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2008, 05:51 PM
hi guys
i got a 51 chevy styleline deluxe sports coupe and im runing 11in disc's in the frount and drum in the back and im runing a chevy 305 v8 and im puting power brkes in to it witch we all know that i need a power brake booster the problom is im limited on space on my firewall 8 to 9 in power booster the most now my ? is out of what car or truck can i take it out of ?
thank you
dan
Old 01-20-2008, 07:23 PM
Last journal entry: my twins
Power Booster
Most Monte Carlo El Camino Brake Boosters Are Nine Inch I Also No That The 67 Ford Galaxie Has Even Smaller Booster The Should Give You An Idea What To Start With. Also Lobecks Has Universal Brake Boosters Or Even Speedway Wil Be Able To Accomidate Your Search
Old 01-24-2008, 09:52 AM
47chevy's Avatar
Last journal entry: Here is the car after paint
I am also limited on the firewall on the 1947 chevy I am working on. The hydra boost brake booster is what I am using. The picture shows an old unit but I have bought a new one for a 1994 GM pickup.
Old 01-24-2008, 10:32 AM
AntnyL's Avatar
Originally Posted by Area_51
hi guys
thank you
dan
If you have some room in the chassis, you can go with an under-floor type brake booster/MC system.
Old 01-24-2008, 09:04 PM
47 chev p/brakes
on the 47 you cuold also ourchase a vaccum booster w/master that mounts under the driver floor againt the frame your pedal will push instead of pivot .
Old 01-25-2008, 09:28 PM
power brake booster ?
i got a 51 chevy styleline deluxe sports coupe and im runing 11in disc's in the frount and drum in the back and im runing a chevy 305 v8 and im puting power brkes in to it witch we all know that i need a power brake booster the problom is im limited on space on my firewall 7 in power booster the most now my ? is out of what car or truck can i take it out of ?
thank you
dan
Old 01-25-2008, 10:42 PM
powerrodsmike's Avatar
Wiki Edits: 161
I merged your threads. You have some good answers already from the first time you asked this question..
Later, mikey
BE different....ACT normal.
Old 02-05-2008, 09:11 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
re: power brake booster and master cylinder ?
FWIW - I found a 7 inch booster to be a little weak on a gm disc setup. Advise you find a 7 inch dual diaphram. They are available aftermarket, not sure about oem.
Old 02-05-2008, 09:15 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
A friend of mine used a booster/ master cyl combo from a Toyota truck on his 38 Pontiac.
Old 02-05-2008, 01:30 PM
47chevy's Avatar
Originally Posted by bigblockblvd
on the 47 you could also purchase a vaccum booster w/master that mounts under the driver floor againt the frame your pedal will push instead of pivot .
I really do not have the room to mount the assembly under the floor. Have the new booster installed. The hoses were expensive but should have real good brakes. I am working on making a pedal assembly under the dash.
Master cylinder without booster? Rons1stRod Suspension - Brakes - Steering 16 11-05-2007 09:06 PM
moving the master cylinder ans brake booster F3RR3T Suspension - Brakes - Steering 7 09-24-2007 10:26 AM
Power brake booster and master cylinders PeteMachinist Suspension - Brakes - Steering 1 02-15-2005 06:49 PM
Power brake master cylinder without booster? BillyJoe Suspension - Brakes - Steering 7 02-12-2004 01:00 PM
