Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power brake booster vacuum canister??
Old 10-21-2004, 05:22 PM
Ed ke6bnl Ed ke6bnl is offline
Ok you all help me to confirm that the booster vacuum canister is defective on
my Ford F1 1950 pu under the floor mounted unit. I test it with a vacuum pump
and it does not pull a vacuum let alone hold a vacuum. I checked the tubing and
check valve they test ok. I bought this new with the master cyl. but it has
never worked and it was over a year and a half since I installed it to find out
it was defective. This is one of those 7" units. What I would like to
know if there is a vehicle make and year and engine that I could use to go to my
local AutoZone or Kragen and ask for a replacement and then get one with a life
time warranty and probably cheaper then I paid for the pair. The place I got it
from are not around to ask about it for a while they are out to some car shows.
Thanks for your help Ed ke6bnl
Ed G
70 miles N.E. of Los Angeles
Agua Dulce, Ca
1963 Econoline pu, 50 f1 Ford PU,48 Ford F3, 70 Chevy lowered shortbed c10,`
1953 chevy AD 3100 pu
70 chevy shortbed C10, 68 Ford Mustang
