Power Brake Boosters - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2006, 06:33 PM
Im going to move the master cylinder on my 57 Chevy pu from under the floor to the firewall. What power booster would work better 8 inch, 9 inch, stock 11 inch, single or dual diphram booster? Truck has disc/drum, 11 inch discs up front and Chevelle rearend drums out back.
Just want to get the right power brake setup the first time.
Gene
Old 05-25-2006, 08:02 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
What are you running for a cam ... do you have low vaccuum readings?
Do you already have Power Steering?
If the answer to the above is "yes" , then I'd definitely look at a hydroboost system. Hydroboost brake boosters use hydraulic pressure (supplied by the p/s pump) rather than a vaccuum diaphragm to provide power "assist".
My brother had a '72 Chevy truck with a fairly "lumpy" cam (low vaccuum). This combination of higher idle speed, stock torque convertor, and low vaccuum made things like parallel parking downright scary. It was fairly un-nerving to step on the brakes ... and not having much assist there.
ID:	12478   Click image for larger version
Old 05-25-2006, 08:33 PM
Got power steering , mild cam with good vacuum.
Hydro booster , thats a thought.
Gene
Old 05-25-2006, 10:11 PM
Whats the reason for moving the brake booster? If its just to get power assist you can get units to fit on the frame in the original position. Both of these places have hydro boost units.
http://www.hydratechbraking.com/products/
http://www.powerbrakesonline.com/
You can also get corvette power boosters in a frame mount.
Good luck.
Kim
Old 05-26-2006, 03:14 PM
Kim57
Whats the 57 ? I have a used 2 different dual master cylinders under the floor with the stock pedal without a power booster, none has been very impressive yet, and im getting tired of working on it under the floor.
CPP looks to have what mite be a nice complete setup for my truck that mounts on the firewall. I was wondering what size of booster was prefered by the folks in this forum ?
Gene
Old 05-26-2006, 09:07 PM
Power Brake booster
Its a pick up. You can see some pics here.
[url]http://www.cardomain.com/ride/2304325
Check out this power booster. These guys are in So. Cal.
http://www.brothersonlinestore.com/p...number=KORN559
Kim
Old 05-26-2006, 09:16 PM
Power brake booster
Check out this power booster. These guys are in So. Cal. Ive dealt with them a couple of times and have had no complaints
Kim
Old 05-27-2006, 09:37 AM
Thanks Kim
That looks like quite a project you have there, good pics.
I have bought some things from Brothers before and also Rob at No Limit.
Looks like your down in their area so you can jump in the car and go to their stores
Gene
Brake boosters crzytchr Introduce Yourself 10 11-23-2004 07:43 AM
FWD power brake technique? Meka Hotrodding Basics 5 06-14-2004 12:09 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 01:36 PM
