Power brake/pedal problem
Hi guys
I am building a '65 Chevy truck which I just started for the first time after a complete engine build last Sunday. I am now trying to tie up some loose ends so that I can take it around the block. I am currently working on the brake system and have run into a strange problem. Here is a quick summary of my system, disc front/drum rear, booster and master cylinder off of '97 s10, disc/drum proportioning valve. I modified the pushrod to ensure proper travel, I have bench bled the master cylinder, bled the entire system, and have a fairly stiff pedal when the truck is not running. As soon as I start the truck and the booster kicks in I can push the pedal to the floor without any resistance. I have vacuum tested the booster and it is good. I have also tried a new master cylinder with no luck. Any thoughts as to what could be causing this issue?
Thanks
Derek
