Power brake system won't lock brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2011, 06:03 AM
Chief-e9's Avatar
I installed dual master cylinder and booster into my 47 stake-bed with 351W engine. I used a kit made to replace the original under the floor. (kit came from MBM brakes and is designed for a 1/2 ton) Thus,had to modify the 3-bolt pattern somewhat by elongating one of the holes plus cut and weld original push rod to the new push rod. Also, installed four 10 lb residual valves as well as a metering block to prevent front end from diving (couldn't really tell any difference with or without block but installed since I had it.) The pedal pressure is lighter now and is much like any vehicle with power brakes and it slows the truck very well. (I am still using the stock drum brakes.) The big problem I am having is when I push the brake pedal as hard as possible to "lock up the brakes" for a panic stop it doesn't happen. The truck will slow down fast like I have an anti-lock system but just won't lock em up. Still trying to figure out why. My mechanic said the wheel cylinders, pads, drums, etc. are good. Wondering if there can be a problem with the size of wheel cylinders as related to size of M/C, etc.? Any ideas and suggestions will be appreciated.
Old 10-20-2011, 07:24 AM
Bonneville462's Avatar
The metering block is designed for cars with disc/drum set ups.. It slows the front disc brake action down so the mechanicals of the rear shoes can catch up and the brakes apply evenly..
I never heard of having a metering valve on a all drum set up.. That's not to say it can't be done though.. I would look into that..
Also, is the master cyl plunger all the way seated when the pedal is not in use..
I get a lot of good suspension and brake info here... http://www.pro-touring.com/forum.php
Old 10-20-2011, 01:25 PM
I suspect that the booster you have is a 7" single diaphram booster. Id so, a double diaphram booster will help. If there is room you can go to a 8" double diaphram booster, big difference.
There is also a difference in master cylinder bore between a F1 and the bigger trucks. You may have to change the master to match the wheel cylinders you have.
The metering block has to be a drum/drum metering block, not a drum/disc. With a dual circuit master cylinder you should use a metering block, it adds protection if one brake circuit fails.
The other thing to check is pedal ratio, you want a ratio of about 5 to one, or you will never be able to apply enough pressure with your foot to lock up the brakes.
Power Disc Brakes vs. Brake booster allclassicsbefore70 Suspension - Brakes - Steering 5 09-24-2011 03:08 PM
line lock system 406MOUSE Suspension - Brakes - Steering 9 05-10-2010 02:16 AM
How do I get rid of air lock in cooling system? Holdon Engine 15 01-06-2010 01:05 PM
Lock Resistant Brake System? hendershot Suspension - Brakes - Steering 4 04-22-2005 09:58 AM
911 Brakes, Master Power Drum Brake Upgrades? frankenvette Suspension - Brakes - Steering 1 07-14-2004 09:04 PM
