Power brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2007, 06:03 PM
Power brakes
I need help - advise. I have a 50 chevy tk 1/2 ton w/mild to hot 350 sb w/ps pw ac @ 4 wheel power disc brakes. All corvette rotors w/ 72 buick Elecrta calipers. Corvette master
cyl. 75 Montecarlo booster. I don't think the Vette cyl @ mont. booster is a good match. I either have too much pedal or not enough. I cut about 4" out of the pedal. Mas. cyl and booster are mounted under floor pan. I kneed a smaller booster 6 or 7" in diam. that will mate up w/ my Vette mas. cyl Sugestions coments welcome
As always Hotrodders BB is.
Thanks Jim Dandy
Old 11-03-2007, 06:40 PM
AntnyL's Avatar
My 55 Chevy 1/2-ton truckrod has a 7" booster mated to a Corvette MC. Works great. Hope this helps.
Antny
Old 11-04-2007, 03:17 PM
power brakes
Antnyl: I appreach your response, this booster, is it a after
market piece, brand name, import or what? Where can I locate one
Jim Dandy
Old 11-05-2007, 05:29 AM
AntnyL's Avatar
Hi Jim,
I got my booster/MC setup from Classic Performance Products. Nice people to deal with. I'd give them a call, I'm sure they can hook you up. I'm not sure who's booster they use in the kit though. I also fabbed a remote reservoir for it. I used Keugel Performance's reservoir cover, and dual plastic reservoirs from a Ducati motorcycle. One for each side of the reservoir. LOL! Hey, it works! This allows me to easily keep an eye on the fluid level, and it eliminates the need for residual valves in the system.
The peddle is soft for the first inch or two of travel, then stiffens after that. It's a very controllable stop. I'm using 11" GM rotors/calipers in front (Caprice), and 11" S10 (Extreme) rotors/calipers in the rear. No proportioning valve. Vehicle is a 55 Chevy half-ton PU/SBC.
Hope this helps.
Ant
std to power brakes on 70 chevelle jwa3 Suspension - Brakes - Steering 6 09-12-2007 07:14 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Power Brakes, im confused bizkit075 Suspension - Brakes - Steering 10 11-18-2003 11:00 AM
My engine specs-will power brakes work? bak9jo Engine 8 07-28-2003 10:24 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
