Power brakes on 1960-1966 Chevy C-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2003, 02:53 PM
Post Power brakes on 1960-1966 Chevy C-10
Does anyone know how to but power brakes on a 1960-1966 Chevy C-10 pick up. I have already bought the disc brake conversion kit and adjustable porportioning valve. But with this kit it allows me to use the stock spindles with a later model mid size car rotors and calipers. But I would like to have power brakes too. But I don't want to spend 400.00 doing it. May be there is a booster small enough to fit under my hood and want need to many modifications! Chevy duty sells on but it's 400.00 bucks, so I was just wondering has anyone else done this with junkyard donor parts. The big truck booster is too tall so it will have to be a small one. Any help would be greatlt appreciated. Thanks alot guys this is the best tech forum on the net.
Old 04-09-2003, 04:14 PM
BOBCRMAN@aol.com's Avatar
Post
I have a 65 step-shortbox waiting in line for project time, and I planned on using the components from a 74-84 chevy 1/2 ton pickup, I have an 80 that I have just Eyeballed the components on but it looks like a very easy swap, the complete front suspension from the later truck unbolts and should go under the 65 easily, this gives me power disc brakes, power steering, and a later, better rear end, also I can use all the factory designed parts for less problems with prop valves and improper brake sizes.Maybe some of these ideas will help?
Old 09-16-2014, 04:53 AM
use a donor truck
I used a 1973 donor truck for the power steering and brakes, I even used the brake lines for the most part considering they were not rusty at all. You should have a double flare kit and know how to use it for this kind of work. keep the connector fitting to a minimum.
Old 09-16-2014, 07:44 AM
RWENUTS's Avatar
What exact year do you have?
60-62 are different than 63-66.
Old 09-16-2014, 08:15 PM
I have a 64, also working on a 66
Old 09-18-2014, 08:53 AM
A 73 to 87 C1500 booster, master cylinder and bracket can be bolted to the firewall using some existing holes and drilling a few more. You can connect it to the stock brake pedal no problem.
The Following User Says Thank You to enjenjo For This Useful Post:
rushautomotive (09-19-2014)
