power brakes on 36 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2002, 06:51 PM
Post power brakes on 36 Ford
I need help on putting the master cylinder and power booster on my 36 Ford. Can anyone help.
Can I use my original brake pedal?
Can I put the setup on the firewall?
Old 07-19-2002, 11:01 AM
beetle9's Avatar
Wink
i Used the unit from a chevy caprice on my 35 sedan. I was fortunate enough to have the original brake pedal still intact, so I just used it. The entire power unit sits close to where the old master cylinder was mounted. Just had to hook up with the pedal. Actually, it worked out very well. I think the 36 is just about the same. Good luck
Old 07-19-2002, 12:45 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Thumbs up
beetle9,
nice set of wheels!
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 07-23-2002, 08:50 PM
Cool
Beetle9,
Talk to me, believe it or not I am working on a 1935 4-door sedan and have a 1979 Caprice donor car. Tell me how you did the brakes. What rear end did you use? I have a Mustang II front end to install and will get rotors with matching bolt pattern, so I need to figure out the rear end. OnceI change the front end, I won't be able to roll it until I get the new front rotors and wheels. If you can e-mail pictures, I would be immensely grateful.
Fred Byam
