Power Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2005, 10:29 AM
Power Brakes
I'm building a "49" Studebaker pickup. MII front end, chev rear end, I would like to add power brakes, what would be a good set up to use?
Thanks,
Old 10-25-2005, 12:51 PM
WELCOME ..........
We have a lot of rodders here and the Mustang II front end is a very popular upgrade they have used.
Master Power Brakes........in North Carolina has a excellent page on Master cylinders.It is here.....
http://www.mpbrakes.com/mpfaqmasters.htm
They also sell everything you will need .....
I have used their parts with good success. I used them because they are close to me. There are others who may use other suppliers....which may do as well.
As the Moderator here.........let me again WELCOME YOU HERE.....
Old 10-26-2005, 09:25 AM
Deuce,
Thanks for the information, I looked at MP's site. My concern is that the pedal
length for their Universal kit's pedal length is 12", the Studebaker's is around 18". Dont know if this will be problem or not.
Thanks
Old 10-26-2005, 05:51 PM
Pony's Avatar
I had a 79 Tbird for a donor car when I did my 53 Ford car. I used the under the dash support structure and used the power booster and m/c from the same car. It fit well under my stock dash, I located it so the booster would clear the 351M engine also from the Tbird and used the Tbird steering column with a custom wheel. It was actually a fairly easy thing to do and solved a lot of fab work and saved a lot of money.
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 07:22 PM
Power Brakes, im confused bizkit075 Suspension - Brakes - Steering 10 11-18-2003 11:00 AM
disk brakes and power steering for 59' chevy marley3 Suspension - Brakes - Steering 3 08-15-2003 12:11 AM
My engine specs-will power brakes work? bak9jo Engine 8 07-28-2003 10:24 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
