Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
Old 11-15-2012, 08:46 AM
chevyrestore's Avatar
chevyrestore chevyrestore is offline
I wouldnt be able to meaure that because the pedal goes through the floor and is non removable since the pedal head is welded to the pedal arm that goes through the firewall and under the floor to the master cylinder setup. There is an adjustment screw im sure you guys know about to adjust the pedal height, can this being out of adjustment cause my concern?
Any way I can measure what youre talking about with the pedal ratio with it being set up the way I described?
