Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
Old 11-27-2012, 10:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are the rear brakes adjusted?
You said you have the CP prop valve. Is it adjustable? If you added it to the MC that already has it's own prop valve, you may have reduced the pressure to the rears too much unless the MC prop valve was disabled.
No way to change the pedal ratio easily, huh? That's a bummer- that might be all it needs if the rear brake adjustment and prop valve deal doesn't pan out.
