Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
Old 11-27-2012, 11:08 PM
gearheadslife's Avatar
gearheadslife gearheadslife is online now
MentalMuffinMan
crack the line for the rears, and see if the pedal now is easier.. I'm guessing here that the rear brakes are in the master port nearest the booster, if the rubber line is failing internally, it block flow under pressure and make it hard to move the piston in the master.. as will a stuck propotioning valve that closed off the rears..
