Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
Old 11-28-2012, 12:07 PM
gearheadslife gearheadslife is offline
Banned
Originally Posted by chevyrestore View Post
The master cylinder is designed by CP also and they said for this setup to work properly I need the disc/disc prop valve and verified they gave me the correct one, only rubber lines are the 12" or so ones at the front calipers, all other lines are hard steel lines.
The rear end is from a 91-92 camaro with discs, how would an adjustment be done on this if any?
PROP valve is NON-adjustable designed for a disc/disc setup as is the master cylinder. When bleeding I get a good squirt from the rear bleeders so I think the valve is working properly and getting sufficient fluid to the rears.
sorry, buddy you HAVE a rubber line at the rear brakes.. the rearend moves, steel line would not work frame to rear..
