Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
  #17 (permalink)
Old 01-18-2013, 09:51 AM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Verify the bore of the master cylinder. My guess is that it is 1 1/8". Install a smaller bore master cylinder to increase line pressure. If all else is good, that will solve your problem. Dropping down 1/16" in bore size makes a very noticeable change in pedal feel. If it is as hard of pedal as you describe, you might consider going to a 1" bore diameter. You will increase pedal travel and increase line pressure.
Regards,
Andy
