Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
  #28 (permalink)
Old 01-20-2013, 04:45 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If you could post a photo of the master cylinder I would like to see the one you are using.
Measure the bore again with a tape measure and see if it is still just over an inch.
Have you checked the adjustment of the push-rod between the booster and master cylinder for proper adjustment? There should be just enough clearance so the pushrod doesn't push the master cylinder at all when it is bolted to the booster.
