Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
  #37 (permalink)
Old 01-20-2013, 07:58 PM
chevyrestore's Avatar
chevyrestore chevyrestore is offline
the rear end is from a 93 camaro with the stock calipers, just verified the pistons move freely and put on brand new pads and rotors, no change in braking.
What insert are you talking about? If its the 3rd pic on the gallery thats what CPP calls the master cylinder pushrod (between the master and booster)
When it had rear drums it did NOT have the prop valve, just a residual valve inline going to the rears, when I switched to disc all I did was remove the inline residual valve and add the disc disc prop valve, used same master cylinder as per CPP's directions (although I cant guarantee the guy that gave me the advise on reusing the master was all that bright).
