Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power brakes dont feel right...any suggestions?
  #77 (permalink)
Old 02-01-2013, 08:53 PM
chevyrestore's Avatar
chevyrestore chevyrestore is offline
No when it had disc drum setup I used the MC with an inline residual pressure valve to provide more pressure to the rears only. When I switched to disc disc all I did was remove the inline residual valve and add the disc disc proportioning valve. I called CPP and they said when I had drums it was set up right and now that it has disc disc its set up correctly also since I removed that residual valve and added the proportioning valve (non adjustable from CPP)
